aluigi Posted September 3, 2003 Share Posted September 3, 2003 Hi all Guys I need your help on this and pretty quick as i have to finish a job and i am stacked as i have promised to incorporate people in the animation. I use i am using viz4 with an ls file and everything seems ok but as soon as i insert a 2.5 businees people in the scene and i press render, viz crashes. any idea and solution to the problem? also do you know of any restriction of working in lp and finishing the job in viz? I appreciate your help Link to comment Share on other sites More sharing options...
Wendelld Posted September 3, 2003 Share Posted September 3, 2003 try excluding the rpc in the radiosity solution. Link to comment Share on other sites More sharing options...
aluigi Posted September 3, 2003 Author Share Posted September 3, 2003 thanks for the help but by default rps people are set to not radiosity Link to comment Share on other sites More sharing options...
Wendelld Posted September 3, 2003 Share Posted September 3, 2003 Is that a Casual 2.5 RPC? Try the 2.5 Bussiness RPC, or other 2.5 Casual RPC. I think its the RPC file that's corrupted. Test render the RPC into a new scene with no other object but the RPC alone. Link to comment Share on other sites More sharing options...
Arnel Posted September 3, 2003 Share Posted September 3, 2003 What version of RPC plug-in you are using? Try to check here at Archvision for technical support. http://www.archvision.com/ViewIncidents.cfm Link to comment Share on other sites More sharing options...
aluigi Posted September 3, 2003 Author Share Posted September 3, 2003 the version is 3.2.6.0. plug in and the file works alone with no geometry. Anyway, i have managed to insert and not crash the machine. But very often happens with the 2.5 business people. cheers Link to comment Share on other sites More sharing options...
aluigi Posted September 3, 2003 Author Share Posted September 3, 2003 guysi have to ask you another question. I have to simulate the glass facade of this tall building (all covered with glass. I tried to use hdri with vray but i cannot control the way maps on the surface. I need a rendering friendly glass as it an animation. Any suggestion? Thank you, your help is highly appreciated. Link to comment Share on other sites More sharing options...
Arnel Posted September 4, 2003 Share Posted September 4, 2003 Try here and do a search for a glass material, they have all that you want to know or learn regarding vray. http://www.chaoticdimension.com/forums/phpBB2/index.php Link to comment Share on other sites More sharing options...
