justintime1 Posted June 11, 2007 Share Posted June 11, 2007 Hi folks Can any one suggest the best way to achieve this mottled, random, masonry effect with a vray textrue in Max ? cheers Matt Link to comment Share on other sites More sharing options...
olli96 Posted June 11, 2007 Share Posted June 11, 2007 unwrap your wall and texture it in photoshop, that would be the best way in my opinion to do it. you should also create a bump and a specular map and then use these textures in the appropriate material slots of your vray material. you can do it also in max, use the blend or composite material to create this kind of effect. here you can find an example: http://www.3dtotal.com/team/Tutorials/london_scene/london_02.asp Olli Link to comment Share on other sites More sharing options...
Nils Norgren Posted June 11, 2007 Share Posted June 11, 2007 Check out this tutorial at "The Area" on using vertex paint with procedural materials. It may work for you. For this to apply, you would prepare a few different tiling block patterns, with different levels of dirt and darkness, then make sure that your model has plenty of geometry (to accept the vertex paint information). -Nils http://area.autodesk.com/learning/tutorials/details/2446/ Link to comment Share on other sites More sharing options...
Andy Park Posted June 12, 2007 Share Posted June 12, 2007 I would normally use the 3dmax Tile material. you can add a color variation to get lighter and darker bricks. Give the tile material multiple layer blended noise maps to create blotches. Link to comment Share on other sites More sharing options...
