Coreyhrpr Posted February 13, 2003 Share Posted February 13, 2003 Question to all you vizers out there. Does anyone know of a MAXscript that is similar to the AutoCAD border command? In Viz I want to be able to select inside a 2D shape and have it automatcially draw lines bordering the shape so i can easily extrude it. Thanks.. Link to comment Share on other sites More sharing options...
quizzy Posted February 13, 2003 Share Posted February 13, 2003 Nope i don't think so.. but you could try on scriptspot.com or tdp.nu But why do you need it?? Link to comment Share on other sites More sharing options...
Coreyhrpr Posted February 13, 2003 Author Share Posted February 13, 2003 I usually model in AutoCAD and Render in Lightscape - doing commercial interior renderings. My company purchased Viz 4 and I thought I would try it out to see if modeling would be faster in Viz then in AutoCAD. Either method I still have to trace around the walls in the CAD file to be able to extrude, but in AutoCAD I can use the border command and that will outline the wall, making it a closed polyline so I can extrude it. The plans the designers give me don't seem to work well with the VIZ snaps :| So I figured if someone knew of a script that could border shapes making them extrudeable, that would cut down on some snap issues and make tracing walls and what not a breeze.... I'm always trying to find better and faster ways to cut down modeling and rendering times since most of these projects are time sensitive with quick turnarounds - as is all 3D projects these days. If anyone else has ideas I’d love to hear them Thanks…. Link to comment Share on other sites More sharing options...
quizzy Posted February 13, 2003 Share Posted February 13, 2003 Why not import the closed plines from autocad into viz? Thats the way I do it... Link to comment Share on other sites More sharing options...
STRAT Posted February 14, 2003 Share Posted February 14, 2003 outline command Link to comment Share on other sites More sharing options...
nisus Posted February 14, 2003 Share Posted February 14, 2003 Why would you need a script for that? Collapse your spline to an editable spline (or add an edit spline modifier), go to sub-object mode 3 (=spline), select your spline and next OUTLINE. That's it rgds nisus Link to comment Share on other sites More sharing options...
