Aaron2004 Posted June 12, 2007 Share Posted June 12, 2007 Hello, I am having a problelm with LWF in VIZ. It seems like MAX users get more options in the Preferences--->Gamma dialog box than us VIZ users get. Can we still do LWF? Thanks! Aaron Link to comment Share on other sites More sharing options...
jophus14 Posted June 12, 2007 Share Posted June 12, 2007 Now that you mention it, I'm asking myself the same thing. I can't quite get the hang off LWF yet and I am using VIZ at work and Max at home, but you are right, the dropdown options are different between the two softwares now that i look at it. I'm not sure if that would be significant when working with Linear Workflow. Hopefully someone could clearify. Link to comment Share on other sites More sharing options...
jophus14 Posted June 14, 2007 Share Posted June 14, 2007 According to another member on this site, LWF can be used in VIZ but he didn't say much more then that. Link to comment Share on other sites More sharing options...
JamesTaylor Posted June 14, 2007 Share Posted June 14, 2007 LWF is possible in Viz... use the same methods as shown in many tutorials. Viz is simply Max with subobject animation, particals and reactors and perhaps a couple of other minor interface adjustments. In Viz under gamma prefences enable it, set display gamma to 2.2 and set bitmap file - Input Gamma to 2.2 and hit OK Link to comment Share on other sites More sharing options...
jophus14 Posted June 14, 2007 Share Posted June 14, 2007 That's what I figured but since I don't properly know or understand LWF I knew that it was something that I was doing wrong opposed to the software. I have seen several tutorials regarding LWF and when I apply the technique to my scenes, my material have to be ridiculously dark to even show up remotely close to the color I need them to be. I heard that using LWF with Vray Physical camera is a great way to work because of the exposure controls, but the physical camera is a task in itself. I will keep on trying to experiment with both LWF and the physical camera in hopes of one day getting both to perform properly. Link to comment Share on other sites More sharing options...
jophus14 Posted June 14, 2007 Share Posted June 14, 2007 The one problem that I just noticed with setting Gamma to 2.2 is that we have no "Affect Material Editor" option in our dropdown so we will never be able to view the 2.2 gamma taking place in our material editor. This once again means that it'll be a guessing game to get the material remotely close to what we want in the end. EDIT: I just found a PDF that says that in the service pack for VIZ 2007 there the "Affect Material Editor" display. http://images.autodesk.com/adsk/files/viz2007_sp1_readme.rtf Link to comment Share on other sites More sharing options...
Aaron2004 Posted June 14, 2007 Author Share Posted June 14, 2007 Jophus...thanks a lot for finding it. That was the discrepency between the two for me. Thanks a million! Aaron Link to comment Share on other sites More sharing options...
Aaron2004 Posted June 14, 2007 Author Share Posted June 14, 2007 MMMMmm...After installing it I still don't get a new option for material editor gamma in the preferences menu. Is it working for you? It shows that I am running SP1 *EDIT*-It looks like it does it autmotically...there is not check box. All clear! Link to comment Share on other sites More sharing options...
