claytonjamesblack Posted June 13, 2007 Share Posted June 13, 2007 First time using Vray. The version is 1.5 and using Max 9. The image has an exterior Vray sun. Can anyone help on getting rid of the over exposed light in the right hand corner of the room. What am I doing wrong? Link to comment Share on other sites More sharing options...
olli96 Posted June 13, 2007 Share Posted June 13, 2007 what kind of color mapping are you using ? Link to comment Share on other sites More sharing options...
claytonjamesblack Posted June 13, 2007 Author Share Posted June 13, 2007 I didn't touch it - So that setting should be set to Exponential? Link to comment Share on other sites More sharing options...
olli96 Posted June 13, 2007 Share Posted June 13, 2007 default is linear, try to switch to exponential or reinhard. with reinhard you can interpolate between linear (1) and expontial (0). Link to comment Share on other sites More sharing options...
claytonjamesblack Posted June 13, 2007 Author Share Posted June 13, 2007 That fixed it - cheers Link to comment Share on other sites More sharing options...
JamesTaylor Posted June 13, 2007 Share Posted June 13, 2007 Something doesn't add up with this... The blown out area suggest that the light source is coming from an external source to the left of thge image yet the direct light hitting the floor comes through the glass door from an external source to the right hand side of the image??? Do you have more than one light in the scene??? Link to comment Share on other sites More sharing options...
claytonjamesblack Posted June 13, 2007 Author Share Posted June 13, 2007 No there is only one light in the scene. I made a mistake in the first thread as I said it was a Vray sun - It's a directional light with vray shadows. It's outside looking down thru the windows. Link to comment Share on other sites More sharing options...
