parker2740 Posted June 13, 2007 Share Posted June 13, 2007 Besides the artifical glow on the image there seems to be something not quite right about this image. Any ideas? Thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted June 13, 2007 Share Posted June 13, 2007 The main thing that catches my attention is that your lights are a bit overpowering. There are too many emitters in the scene. Try cutting back the number of lights.... and the intensity. Your result from too many lights is that everything looks flat, and you don't get much shadow definition to add contrast in the scene. you may want to even try just lighting the kitchen and bedroom and only illuminate from the window for the seating area. Link to comment Share on other sites More sharing options...
rpompeu Posted June 14, 2007 Share Posted June 14, 2007 As BKittsARC said, it lack contrast, chhange your lights setup. A little more contrast in photoshop to see the difference, but go by changing the lights. Link to comment Share on other sites More sharing options...
alfienoakes Posted June 14, 2007 Share Posted June 14, 2007 BKittsARC said: The main thing that catches my attention is that your lights are a bit overpowering. There are too many emitters in the scene. Try cutting back the number of lights.... and the intensity. Your result from too many lights is that everything looks flat, and you don't get much shadow definition to add contrast in the scene. you may want to even try just lighting the kitchen and bedroom and only illuminate from the window for the seating area. Brians nailed it. You have too many lights. Cut it back to just environment and a sunlight light source, and work forwards from there, adding to the scene till it looks right. Plus it looks like the lounge is shoe horned into the corner by the window, when there is a great big space at the front of the camera.. Link to comment Share on other sites More sharing options...
wodewil Posted June 19, 2007 Share Posted June 19, 2007 Hej James! Quite nice picture You've done great material in refrigerator side! Could you post some settings for that material- shaders, if anisotropic: what range and what direction, reflection settings and so on.... And what kind of tekstures did You use. Please Thanks Lukasz T. Link to comment Share on other sites More sharing options...
ebad Posted June 19, 2007 Share Posted June 19, 2007 Nice! I think something is wrong with the white THIN door!(Just in the center of image). Link to comment Share on other sites More sharing options...
parker2740 Posted June 20, 2007 Author Share Posted June 20, 2007 wodewil said: Hej James! Quite nice picture You've done great material in refrigerator side! Could you post some settings for that material- shaders, if anisotropic: what range and what direction, reflection settings and so on.... And what kind of tekstures did You use. Please Thanks Lukasz T. The texture for the fridge was a rendered image of the other side and then manipulated in Photoshop. Originally, it was a reflective surface but the rendertime were too crazy. Link to comment Share on other sites More sharing options...
wodewil Posted June 20, 2007 Share Posted June 20, 2007 Hej James! Its quite good idea! Thanks for that trick! I just wonder if it could be done with cubemap... lets try See You later Link to comment Share on other sites More sharing options...
