Backburner Blues
Justin Hunt
Backburner 3.2.1 is giving me the S&$ts
I can get manager to talk to monitor and server, but not to Max.
- Server is giving me this error ERR Unknown command (2077656E) from 10.7.0.144
- Manager is reading failed to respond to registration request, but then connecting after I restart server
- Max is giving me a "missing message" error, and not connecting to manager and freezing
- Manager, server and monitor are exempt from firewall and port 3234 is open.
What am I overlooking
JHV
I am rendering locally, so the master is the slave (if that makes since)
searching by IP, although subnet doesnt work either.
Crazy thing is it was working a week ago but someone else set off a job from their machine as master and mine as a slave. since then it hasnt worked.
JHV
ok, so right now the manager should running on your local machine
the slave should be running as well with the subnet mask set with your subnet mask of your system
(you can check by going to start>run> type "cmd" > then type ipconfig /all)
now when you net render with max, make sure that that same subnet mask is used there
also check to see if monitor is set up for the same subnet mask and see if it can connect to the server and manager.
I'll still be up for a while if your still trying options
forgot to ask, are you running 32-bit or 64-bit
all are using the correct subnets, monitor can see manager and server.
I'm on 32-bit
I turned on the degug in server and monitor. When I submit a job from max, it seems that serve and manager get stuck in a loop of pinging each other
JHV
