rachel Posted June 4, 2003 Share Posted June 4, 2003 hello all, i am looking for a script to convert a 3d studio max 5 file into a viz 4 file. any idea where I could get that? Many thanks, rachel Link to comment Share on other sites More sharing options...
quizzy Posted June 4, 2003 Share Posted June 4, 2003 There is a script called Back from five. Its for converting max5 files into max4 files. and it works, i've tried.. It uses maxscript files to recreate the scene, so if max4 talks the same maxscript as viz4 it should work. one thing though... you have to have max5, load the scene and run the script... mzzl Link to comment Share on other sites More sharing options...
quizzy Posted June 4, 2003 Share Posted June 4, 2003 check http://www.scriptspot.com for the script.. if you want, and you don't own MAX5, I could do the trick for you, just send me the max5-file by e-mail... if it isn't too big..... Link to comment Share on other sites More sharing options...
nisus Posted June 8, 2003 Share Posted June 8, 2003 The script doesn't really works well in max3.1, because it handles mapping wrongly... Better export to 3ds if you need the mapping too... rgds nisus Link to comment Share on other sites More sharing options...
