Bedroom again
innerdream
how many lights you got in the scene? something don't look right, your not getting a good feeling of depth.
Mark,
I totally agree! I'm not sure if it's the render engine, Cheetah? I have the Skylight/sun outside, the bed side light, the light on the cabinet and two point lights, one above the bed and one in front of the bed. The lights are pretty low intensity. The render is very noisy so I'm doing another one now with less noise. I have to admit though I haven't seen a render in this software that has the depth I would like yet.
Personally I don't like adding fill lights like the 2 point lights you have above the bed and in front of the bed, even if they are low intensity, have you rendered the image without those 2 lights on?
I would only have lights where there are light sources e.g the sun and your lamp, and let your GI sort out everything else, you can always mess with GI settings and bounces etc to get your light to fill the room better, although I don't know how you would do it in cheetah as I don't use it. good luck with it :)
Thanks Mark I'm going to try that. The radiosity tag in Cheetah is very limited as far as adjustments, all you can really do is increase the intensity/decrease of the radiosity and change the samples. It doesn't have a bounces function so to speak I guess that's what intensity is suppose to behave like.
