Cannot create bitmap
Msamir
After about 2 hours of rendering an image at 3000 x 2200 I cant save it, I tried saving as every type but it keeps giving me the same error ( cannot create bitmap) I even tried duplicating the image to Maxs frame buffer but also gives me the same error and I dont want to rerender the image, Can anybody help ?
Thanks in advance.
I get this error on a regular. I heard it's because the memory is used during the render process and there isn't enough memory to save the image after the rendering is complete. I use a program called SnagIt and I just zoom in on the rendered image and do a screen capture and then pan over and repeat the process. I then go into Photoshop and combine all of the images. It's a pain, but it works.
I've to render 2,9m high and 3,9m wide in 100dpi !!!! last month. I've render it (Vray) in 50dpi using "crop" during render. so I've render 4 pieces and combine it in PS!
That was the biggest thing I've ever made!!! :)
see You later
