jphelps Posted June 18, 2007 Share Posted June 18, 2007 We've been modeling in AutoCAD using ABS walls and mass elements. We're just starting out with V-ray rendering basic white mass models and are noticing alot of blotchiness along edges and where one or more mass intersects. We've also noticed that when we model with AutoCAD 3d solids we don't get any of the blotchiness with the exact same V-ray lighting and set-up. We would prefer to use the ABS walls and mass elements so is there a fix out there for the blotchiness problem? Link to comment Share on other sites More sharing options...
nivvu Posted June 18, 2007 Share Posted June 18, 2007 y dont u jst post your vray settings.....lets c then... :-) srinivas Link to comment Share on other sites More sharing options...
jphelps Posted June 18, 2007 Author Share Posted June 18, 2007 Here are screenshots of our V-ray rendering settings Link to comment Share on other sites More sharing options...
jphelps Posted June 18, 2007 Author Share Posted June 18, 2007 Plus one more Link to comment Share on other sites More sharing options...
Tonsgaard Posted June 19, 2007 Share Posted June 19, 2007 I've Had similar problems with ADT and vray... I think it comes down to multiple faces in the exact same location. when several faces lies on top of each other in the exact same plane vray freaks out. What you need to do is to create a tiny gap between wall elements and so... Stupid, but necessary as far as I know... Might just give all objects a push modifyer with a very small negative value!?! Link to comment Share on other sites More sharing options...
nivvu Posted June 21, 2007 Share Posted June 21, 2007 hi, me also faced same problem.......check off the vray gi environment option in vray environment menu.....and then c.......instead of putting on the skylight ovverride option on......check off it and put a vray dome light. u dont get any blotches thn.....and using of hdri is up to u my dear.... Link to comment Share on other sites More sharing options...
