gazbo Posted June 18, 2007 Share Posted June 18, 2007 My first post here so hi everyone, Some help would be much appreciated with the following problem: I'm getting the following error when I try to render full-size for print (4000 x 3000) RCFG 0.3 error 541001: failed to create frame buffer 0: C:\DOCUME~1\Gareth\LOCALS~1\Temp/fb000.0.3920 (Not enough storage is available to process this command.) Don't know if by storage it means hard drive or RAM. My C: has nearly 70 gig of space, the system is not amazing but it's not bad, I've got an AMD dual core 5600 with 2 gigs RAM. On the scanline, I had 500mb ram and it never ran out of memory it just took ages, which was fine, I just used to leave it running overnight. Link to comment Share on other sites More sharing options...
Tommy L Posted June 18, 2007 Share Posted June 18, 2007 you could render in strips. Link to comment Share on other sites More sharing options...
gazbo Posted June 18, 2007 Author Share Posted June 18, 2007 Cheers for the reply stripes looks promising but can you do it with just one machine? Most of the people in our office have laptops that they take home. Was thinking about rendering passes would that help do you think? Link to comment Share on other sites More sharing options...
Tommy L Posted June 18, 2007 Share Posted June 18, 2007 It would, depends how you break down the passes though. Stripes can be done on one machine, yes. You need to set up backbuener on the one machine, send jobs to itself and queue the jobs. Link to comment Share on other sites More sharing options...
gazbo Posted June 18, 2007 Author Share Posted June 18, 2007 Ok, read the help files, got the stripe render but now I've got loads of buckets that seem to not want to render, see attached. Sorry to keep bugging you, any ideas? Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 18, 2007 Share Posted June 18, 2007 have a look on http://www.mymentalray.com forum , there is a thread dedicated to this sort of problem in Max JHV Link to comment Share on other sites More sharing options...
pixelperfectg Posted June 19, 2007 Share Posted June 19, 2007 Try Zap's script: http://mentalraytips.blogspot.com/ Link to comment Share on other sites More sharing options...
gazbo Posted June 22, 2007 Author Share Posted June 22, 2007 Thanks guys, I've tried zap's script which is really cool, but for some reason I'm getting differences in the tiles. Some blend seamlessly others have completely different colours. I'm playing around with the overlap settings but this is really eating up a lot of time. Cheers for the help though. Link to comment Share on other sites More sharing options...
