Looking into Modo...
RyanSpaulding
Modo is a great program. I have been using it for production work for more than 6 months now without major complains. Modo 203 has a dxf importer but it is far from perfect. I use AccuTrans.
http://forums.luxology.com/discussion/topic.aspx?id=13431&show=accutrans
I do not use xfrog or onyx but you can find some info here:
http://forums.luxology.com/discussion/topic.aspx?id=14907&show=XFrog
RPC content is not supported. The snap systme in Modo 203 is not perfect but it will be greatly improved in Modo 301. 301 will also support IES lights and it will have a basic animation system.
http://www.luxology.com/whatismodo/301/
Here are some of my favorite works done using Modo by other artists:
http://www.luxology.com/community/profile.aspx?name=Khalid+muharraqi
http://forums.luxology.com/discussion/topic.aspx?id=17689&show=captain
Give the demo a try and see it works for you.
Ernesto
  • 3 weeks later...
Thanks guys.
I'm more interested in the rendering engine than anything. I'll continue to build in MicroStation...but there simply isn't much exterior arch renders to my knowledge. I cant figure if I want to bit the bullet and hope things look nice...or if I should look elsewhere like Cinema4D or something like that.
Arg. I hate the choices.
Cool. Thanks for the info man!
Want a few crits?
1. Where's the bump/displacement map in your bricking and shingles?
2. Your brick texture repeats funny...you need to go into PS and crop out either the top or bottom row cause as they meet, the align up as opposed to offset.
