godchi86 Posted June 21, 2007 Share Posted June 21, 2007 Hi, Just wondered if anyone has a setup for vray that they think is the best way to render interior scenes? Can a render be done quite quickly and be of a good/great quality? or am i wanting too much from this program? Any suggestions would be greatly appreciated! Thanks for your help. Link to comment Share on other sites More sharing options...
tayrona Posted June 21, 2007 Share Posted June 21, 2007 I usually work with some settings to preview,while i am working and for final render I use diferent settings. Next settings have work for me: for previews: desactive antialiasing and use low preset in irradiance map (use imap + qmac in GI). if you want change rates -3,-3 in imap, to get just one pre-pass. In system, adjust Render region division to 32. For final render activate antialiasing (depending on your render you should choose what kind), use light cache, not qmac as secondary GI engine (remember that light cache is going to be precalculeted so be patient) and depending on your render choose Medium or HIGH quality in IMAP settings. dont forget to change de render region division to 64 again. Maybe those are not the perfect settings but is a start. good look;) Link to comment Share on other sites More sharing options...
aaron-cds Posted June 21, 2007 Share Posted June 21, 2007 If you want fast results for interiors go with irmap / lc instead of irmap / qmc. Link to comment Share on other sites More sharing options...
Advisor Posted June 22, 2007 Share Posted June 22, 2007 Imap you can get away with medium most of the time(yes for final output) and 35 or less hs subdv. and lightcahe samples Defaults to a 1000 actually you can get away with 600 most of the time. Link to comment Share on other sites More sharing options...
