dpcaltdcah Posted June 21, 2007 Share Posted June 21, 2007 we just got some new axyz people with mocap data and are having fun playing with them. but a couple of them have a problem when you group them and them move them from their original location. this happens (see attached image) and it gets worse the farther you move them. anyone? Link to comment Share on other sites More sharing options...
stone145 Posted June 21, 2007 Share Posted June 21, 2007 ...dont do it. hehe Link to comment Share on other sites More sharing options...
dpcaltdcah Posted June 21, 2007 Author Share Posted June 21, 2007 gee thanks Link to comment Share on other sites More sharing options...
Paul Twyman Posted June 21, 2007 Share Posted June 21, 2007 Hey there, Go to the physique modifier on the figure mesh and in the envelope sub-object select the head or neck envelope (which ever one contains the problem area) and increase the strength slightly. 1.1 or 1.2 should do it. Think this should help Link to comment Share on other sites More sharing options...
dpcaltdcah Posted June 21, 2007 Author Share Posted June 21, 2007 ok, that worked. but then when I closed the group again and moved him again, his bones separated from the mesh and moved at a different speed somewhere else. Link to comment Share on other sites More sharing options...
Paul Twyman Posted June 21, 2007 Share Posted June 21, 2007 Have you scaled the figure correctly to your units using figure mode (figure modes not still on is it??) in the biped panel? There's a tutorial here on the aXYZ website that tells you exactly what to do. http://www.axyz-design.com/axyz-design-3d-humans-characters-products-tutorials.php?ccSID-d41d8cd98f00b204e9800998ecf8427e=5f7918f48a69bba9859d2270618145f3 make sure you follow it exactly, you then may have to do what i said previously in order to get those problem vertices to follow the rest. If it's grouped it should just be the biped grouped without the mesh, the mesh should follow the bones without being selected. Hope this helps. Link to comment Share on other sites More sharing options...
dpcaltdcah Posted June 21, 2007 Author Share Posted June 21, 2007 yes, that's the first thing we did. and we followed very carefully. I emailed the guy from axyz and he said you just should't group them. you should use the move all mode instead. that seems dumb but it works. Link to comment Share on other sites More sharing options...
Paul Twyman Posted June 21, 2007 Share Posted June 21, 2007 Yeah i noticed it says to do that now, it definietly used to say "select all the bones and create a group" i just had a look at the pdf i downloaded at the time. Oh well, as long as they're working Link to comment Share on other sites More sharing options...
alfienoakes Posted June 22, 2007 Share Posted June 22, 2007 looks like a scene out of "the Omen"..!!! Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 22, 2007 Share Posted June 22, 2007 This is how I move them around, it seem to work in most cases. 1. select xxxx-bip 2. go to motion pannel 3. under biped select load file 4. select approprate .bip file 5. set amimation to frame 0 6. under layers select "create layer" 7. move character to desired location 8. under key infor click "set key" This works for me I hope it works for you, I do wish that AXYZ could come up with a plugin that made these figures as easy to use as RPC's. Link to comment Share on other sites More sharing options...
rotten42 Posted June 22, 2007 Share Posted June 22, 2007 we just got some new axyz people with mocap data and are having fun playing with them. but a couple of them have a problem when you group them and them move them from their original location. this happens (see attached image) and it gets worse the farther you move them. anyone? It looks like a "kill shot" like you would see on CSI:p Link to comment Share on other sites More sharing options...
