Quicktime VR
Devin Johnston
are you locked in to using the built in max exporter....?
I've found this to be an easy work flow for making QTVRs from vray...
http://www.cgarchitect.com/vb/23369-freeware-qtvr-setup.html
setting it up the first time takes a few minutes but once you have it set, it's as easy as render to spherical camera, then drag and drop on to the plugin, you you have your QTVR.
What I meant was will the panoramic exporter that comes with max export a Vray scene as a QuickTime VR? Every time I try I get nothing.
actually it doesn't export a vray scene (or a max scene for that matter), it renders a panoramic image which you can then export as quick time vr (or a couple of other formats if I recall correctly). it doesn't work with vray cameras though.
or render a image with the vray camera (in the render options ) spherical , 360 degrees and use pano2qtvr to do the qtvr export ... that is easier i guess
I've also done this but I only have 3 choices to pick from once I load the Tiff file they are Equirectangular, Cubic, and Cylindrical but none of these will work. After the quicktime is created all I get is a compleatley white screen.
Now I'm getting a message that says "windows cannot find D:\3D\panoramic'. Make sure you typed the name correctley , and then try again. To search for a file, click the start button, and then click search."
hmmm... sometimes it has problems with long names....is your file name anything interesting? stay away from long names, underscores, and spaces. I keep my files for the program in a folder on the root of the drive in a folder called "panocube" and I always name my renders simple, such as pod1.jpg and it never has any problems.
there was a short learning curve to learning how to get the prog to work.... but for free it's worth beating your head on the wall a couple of times.
I was wondering why it wasn't working, Devin... I mean, I have succesfully used VRay to create QTVR panoramas (yes, with Max's native tool) several times, never had a problem.
One question that comes to miy mind on this is: isn't there a XP64 version of QT?
