generating camera views without using 'Hidden Line Projection"?
yushi
Hi Everyone
I wanted to know if there's a way to generate a perspective view from a camera without changing the view to camera. Something like sections and elevations which you can update them automaticaly when you change the model. Does anyone know about a soloution?
I can generate isometrics using elevation lines and 3drotating them. but not perspective!
regards
i'm having a hard time understanding your question, but i'll take a stab at a possible solution.
perspective is a system variable. type it in and change to '1' (on)
even a plan or elevation can be turned into a (one point) perspective
hope that helps...
paul
hope that helps...
paul
Well let me say it this way...
In ADT you draw the building in 3d and put a section line in front of it and it automaticaly creates a section for you. Whenever you change the design, you just update the section and it is changed according to your design.
I want to generate a perspective like this. I want it updateable.
Regards
