Dan J Posted March 3, 2004 Share Posted March 3, 2004 Hey everyone, I'm on Viz4 and I'm trying to get an object to glow using the lens effect-glow. I've tried to use the material channel, sub-object materials, and use the explicit map channel, but nothing seems to work to get the object to glow. Picking a light will glow, but not a box or any other object. Any help would be great. Thanks. Dan Link to comment Share on other sites More sharing options...
M. Steadman Posted March 3, 2004 Share Posted March 3, 2004 Hello Dan, I think there is a tutorial at CG;architect by Smoke 3d that may have the answer you're looking for. http://www.cgarchitect.com/resources/tutorials/smoke3d/tutorial16.asp Good luck Link to comment Share on other sites More sharing options...
Dan J Posted March 3, 2004 Author Share Posted March 3, 2004 M and all, I should be a little more specific. I'm trying to make an object (not a light source) glow using the "Rendering Effects-Lens Effect-Glow" which should be able to do with a map channel, but I can't seem to get it to work in Viz4. Any help would be great. Thanks. Dan Link to comment Share on other sites More sharing options...
quizzy Posted March 4, 2004 Share Posted March 4, 2004 I think you have to do this by using the object ID channel or G-buffer. Link to comment Share on other sites More sharing options...
Dan J Posted March 4, 2004 Author Share Posted March 4, 2004 Quizzy, That's what I thought and tried it, but nothing. When I had Max this was an easy thing to do, but in Viz I don't seem to get it to work as it's noted in the "help" files. A tutorial would great, if anyone knows of one for Viz. Thanks Link to comment Share on other sites More sharing options...
siliconbauhaus Posted March 4, 2004 Share Posted March 4, 2004 have you made the element you want to glow a seperate ID and assigned it in the effects rollout ? Link to comment Share on other sites More sharing options...
Dan J Posted March 4, 2004 Author Share Posted March 4, 2004 Here is an screen image of what I have setup. http://www.cgarchitect.com/forum/filepush.asp?file=glow-setup.jpg If I'm completely off, show me the best way to set it up. Perhaps with a screen image post. That would be very helpful. Thanks. Link to comment Share on other sites More sharing options...
DelfoZ Posted March 4, 2004 Share Posted March 4, 2004 try this Link to comment Share on other sites More sharing options...
Dan J Posted March 4, 2004 Author Share Posted March 4, 2004 Huhhhhhhhhhhhh! I'm so dense sometimes. Sheesh. Right click on the object-object properties-G Buffer object channel set to 1 or Material editor-material assigned with material effect channel set to 1 (or under one of the map channels for more interesting effects), then in the rendering effects-glow element- options tab- images sources object or effects ID set to one of the above choices. Thanks for jogging my memory a bit. Dan Link to comment Share on other sites More sharing options...
DelfoZ Posted March 4, 2004 Share Posted March 4, 2004 or this : Link to comment Share on other sites More sharing options...
Dan J Posted March 4, 2004 Author Share Posted March 4, 2004 Thanks DelfoZ, I must have been picking up on your telepathic waves when I was figuring it out. We posted just about the same time. Thanks again. Dan Link to comment Share on other sites More sharing options...
DelfoZ Posted March 4, 2004 Share Posted March 4, 2004 hehe, yes. at same time .. i was a little late. anyway i hope this help . Link to comment Share on other sites More sharing options...
Lily Wei Posted August 14, 2007 Share Posted August 14, 2007 I have the same problem. I tried the above and it doesn't work... am I missing something? Link to comment Share on other sites More sharing options...
