nivvu Posted June 25, 2007 Share Posted June 25, 2007 hi all... thrz a small problem with rpc... they flicker in vray exterior animation.. i have workd the file in max8 and vray 1.47.03 vray settings are.. Image sampler : Adaptive subdivision 0,2 first gi engine irriandance map second gi engine lightcache. irrandance map preset : verylow(low configure system in my office) lightcache : 800 , sample size: 0.02. and the scale is in screen mode. though i didnt create vrmap coz of lesstime. i have created vrl map for every 50th frame of my 3000 frame animation. thts it friends....normal vray settings but gettng flickering in static rpc. they dissappear in a frame and appear after 10 frames in my animation. is there any setting in rpc controls or in vray by wihch we can contrl this happeing(flickering of rpc.) please assist me as therez a deadline to meet.... :-( thanks in advance.... Link to comment Share on other sites More sharing options...
kippu Posted June 25, 2007 Share Posted June 25, 2007 sadly rpcs have a lot of problems with vray and i have no workaround for it Link to comment Share on other sites More sharing options...
pyang Posted June 25, 2007 Share Posted June 25, 2007 you've got a problem. no way to fix it in 1.47.03. upgrade to 1.5 rc3. that shall rid of rpc flickering. hi all... thrz a small problem with rpc... they flicker in vray exterior animation.. i have workd the file in max8 and vray 1.47.03 vray settings are.. Image sampler : Adaptive subdivision 0,2 first gi engine irriandance map second gi engine lightcache. irrandance map preset : verylow(low configure system in my office) lightcache : 800 , sample size: 0.02. and the scale is in screen mode. though i didnt create vrmap coz of lesstime. i have created vrl map for every 50th frame of my 3000 frame animation. thts it friends....normal vray settings but gettng flickering in static rpc. they dissappear in a frame and appear after 10 frames in my animation. is there any setting in rpc controls or in vray by wihch we can contrl this happeing(flickering of rpc.) please assist me as therez a deadline to meet.... :-( thanks in advance.... Link to comment Share on other sites More sharing options...
Tommy L Posted June 25, 2007 Share Posted June 25, 2007 Render them out in a matte file (scanline). Composite in post Link to comment Share on other sites More sharing options...
tayrona Posted June 25, 2007 Share Posted June 25, 2007 If you want to use RPCs with vray, dont render them with your geometry, first render the geometry alone, then render RPCs alone with alpha channel and finally compose. (use matte option for shadows and objects in front of rpcs) Link to comment Share on other sites More sharing options...
nivvu Posted June 26, 2007 Author Share Posted June 26, 2007 hi pyang, could u tell me any vray settings to avoid flickering of rpc...???? i have vray1.5r.c3........please tell me any settngs to reduce flickering brother so tht i can use vray1.5rc3 for my next animation project... nivas. Link to comment Share on other sites More sharing options...
tayrona Posted June 27, 2007 Share Posted June 27, 2007 there are no settings to avoid flikering!! vray and rpcs are not compatible, you must render separetely and then compose...!!!! Link to comment Share on other sites More sharing options...
Advisor Posted June 27, 2007 Share Posted June 27, 2007 there are no settings to avoid flikering!! vray and rpcs are not compatible, you must render separetely and then compose...!!!! Same Here Link to comment Share on other sites More sharing options...
nivvu Posted June 28, 2007 Author Share Posted June 28, 2007 hi all.... thanks for ur valuable advices. i wil go through ur methods and learn the composing option.. hope u will assist me in future also.. thanks again.. nivas. :-) Link to comment Share on other sites More sharing options...
nivvu Posted June 28, 2007 Author Share Posted June 28, 2007 hi friends. thanks for ur assistance... i have gone through matte option in 3dsmax...its not getting in to my mind... plz could u let me know if thrz any tutorial online .... or if plz could u tel me the steps.... iam in desparate need to avoid flickering in rpc.... regards thanks nivas :-) Link to comment Share on other sites More sharing options...
tayrona Posted June 28, 2007 Share Posted June 28, 2007 Ok first step: render your scene without RPCs, (save your rendered images files in a separate folder) then Render it with RPCs but converting all geometry (unless rpcs) to matte object (vray props) -make sure alpha contribution is -1, shadow and affect alpha activated. Make sure that Rpcs are included in light (lights exclude them by default) and cast shadows is checked in all of them Render scene again and save files in a format with alpha channel (png is my favorite) Now you have 2 animations, you must compose them in premiere or another editing software. I think is the easiest way to work vray and rpcs. hope you got it. Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 29, 2007 Share Posted June 29, 2007 I'm just curious what you guy's use for 3D people in your animations if your not using RPC's? I've used AXYZ people but they are only good if they are far enough away from the camera that they don't appear monstrous. What do you do if you need 3D moving people in an animation? Link to comment Share on other sites More sharing options...
