nivvu Posted June 29, 2007 Share Posted June 29, 2007 hi friends, thrz a small modeling doubt... i have to model a wal with grooves. it has also window openings and door openings. traditional way is to extrude or loft the groove profile and bollean the openings ......but i dont want a boolean object... can we have spline modelled groove wall with openings..???? plz let me know thanks nivas Link to comment Share on other sites More sharing options...
Aaron2004 Posted June 29, 2007 Share Posted June 29, 2007 When you loft the wall, make sure that it has some path segments...then erase the polygons you want the window to be at and use the bridge command to connect the two sides together. Since a picture is worth a thousand words, see the attachments. Link to comment Share on other sites More sharing options...
nivvu Posted June 29, 2007 Author Share Posted June 29, 2007 thanks a lot!!!!! Link to comment Share on other sites More sharing options...
