JPS Posted June 23, 2003 Share Posted June 23, 2003 Does anyone know how to do easy and realistic water edges so that they match with the bump map? For instance this image web page has water and then when the water meets the edge of the seawall it looks like a razor sharp straight line. I know I can take it into PS and do some post production trick, but is there a way to do it in the software? Thanks. RGDS, J. Link to comment Share on other sites More sharing options...
kid Posted June 23, 2003 Share Posted June 23, 2003 Displacement mapping would do it. Using the same map for displacement as you are for bump, but Max/Viz displacement mapping is practically useless as it requires so many polygons (and RAM) to get satisfactory results. You could give it a try, but I'd do it photoshop if it were up to me. Link to comment Share on other sites More sharing options...
JPS Posted June 23, 2003 Author Share Posted June 23, 2003 Yes, displacement map would be the way to do it, but your right about the extra polygons been added. Right now the water is just one large plain (2 polygons)with a water bump map. What I was thinking of doing is just modifying the outer area of the plain around 1' in from the edge to add more polygons just to that area so that the displacement works only near the edge and dosent add to many polygons to the whole scene, but I wanted to see if anybody else had any better ideas. Anyone? RGDS, J. Link to comment Share on other sites More sharing options...
kid Posted June 23, 2003 Share Posted June 23, 2003 you could paint an opacity map to make the edge of the plane look like its not dead straight. Link to comment Share on other sites More sharing options...
nisus Posted June 23, 2003 Share Posted June 23, 2003 Tackle the place where the water hits the wall with some grunge/dirt map so you won't notice the seem anymore... This way, you won't add extra faces rgds nisus Link to comment Share on other sites More sharing options...
Tango Posted June 25, 2003 Share Posted June 25, 2003 I don't know what happend with the link. I can't see anything. Link to comment Share on other sites More sharing options...
JPS Posted June 26, 2003 Author Share Posted June 26, 2003 Sorry Tango, I took them off the site. If you still want to see it, these are the final 2 images. I did a little subttle effect in PS for the water. Let me know what you think. web page 1 web page 2 RGDS, J. Link to comment Share on other sites More sharing options...
