godchi86 Posted July 1, 2007 Share Posted July 1, 2007 Hi, The image attached is a conceptual render of space in a bar that i am designing. Im quite happy with the render as it is the best i have produced so far since i started teaching myself Vray. Something that im not sure about is the speckled areas near the window on the left hand side. Any advise on improvements and techniques would be greatfully received. Cheers, Richie Link to comment Share on other sites More sharing options...
NOOXY Posted July 1, 2007 Share Posted July 1, 2007 concept looks cool so far..but think the light burns in a bit too much.. Keep us posted as you go along..nice:cool: Link to comment Share on other sites More sharing options...
godchi86 Posted July 1, 2007 Author Share Posted July 1, 2007 How do you suggest making the light burn in less? Im quite new to this. Thanks. Link to comment Share on other sites More sharing options...
tayrona Posted July 1, 2007 Share Posted July 1, 2007 If your color mapping is in linear multiply , change it to exponential, burning will dissapear. Link to comment Share on other sites More sharing options...
Rafique Posted July 1, 2007 Share Posted July 1, 2007 its very fine work:) Link to comment Share on other sites More sharing options...
godchi86 Posted July 1, 2007 Author Share Posted July 1, 2007 Thanks for the tips! Any other alterations you guys would make? Thanks Link to comment Share on other sites More sharing options...
godchi86 Posted July 1, 2007 Author Share Posted July 1, 2007 I have attached my newest render that has altered colour mapping, the light in the scene is not as intense which i think looks more realistic, im still having problems with the noise type effect! The resolution on this one is smaller to save time rendering. Any ideas? Link to comment Share on other sites More sharing options...
bjeves Posted July 2, 2007 Share Posted July 2, 2007 its coming along nice but to me it is looking a bit flat and the colours are a bit soft. May be try giving it a bit of a lift with say maybe give the floor more glossiness and allow a bit of reflection. Link to comment Share on other sites More sharing options...
sterealkey Posted July 2, 2007 Share Posted July 2, 2007 What will the bar counter be made of? It seemsquite long and doesnt seem to be well supported. What materials do you have in mind to build it? Just curious The render already looks 20x better than the first one. Link to comment Share on other sites More sharing options...
godchi86 Posted July 2, 2007 Author Share Posted July 2, 2007 sterealkey said: What will the bar counter be made of? It seemsquite long and doesnt seem to be well supported. What materials do you have in mind to build it? Just curious Not sure as of yet? The bar is at a conceptual stage at the minute, im sorting out layouts and spacial arrangments. Would you suggest a particular material? There may need to be drinks storage benieth the bar?? Link to comment Share on other sites More sharing options...
sterealkey Posted July 2, 2007 Share Posted July 2, 2007 Oh okay I see. Sorry didnt mean to jump the gun and start criting your work at conceptual stage. Bar material would depend on the budget, normally if I do something for a client I would suggest fancy materials, but if I do it for a friend or for myself then I cheap it out. If you want beverage storage underneath then you're obviously going to close it off underneath so the fridge wont be visible from the front, I reckon then it would be nicely supported, and you could go for duco sprayed medium density fibre (supawood) , that curve on the end is going to be tricky. Those curves are easier on thicker objects. That would be the cheapest solution, they teach us to think cheap here in south Africa Link to comment Share on other sites More sharing options...
godchi86 Posted July 2, 2007 Author Share Posted July 2, 2007 Good Thinking! Cheers for the suggestions. Link to comment Share on other sites More sharing options...
PAWUK Posted July 3, 2007 Share Posted July 3, 2007 godchi86 said: Not sure as of yet? The bar is at a conceptual stage at the minute, im sorting out layouts and spacial arrangments. Would you suggest a particular material? There may need to be drinks storage benieth the bar?? Hi Why dont you carry the frosted effect around to the underside of the bar and have it back lit. Link to comment Share on other sites More sharing options...
godchi86 Posted July 3, 2007 Author Share Posted July 3, 2007 PAWUK said: Why dont you carry the frosted effect around to the underside of the bar and have it back lit. Nice idea, Would you just use vray lights for this? Link to comment Share on other sites More sharing options...
PAWUK Posted July 4, 2007 Share Posted July 4, 2007 Hi Heres a couple of examples, basic but Iam at work at the moment . I prefer the look of the vraylight (kept visible), there might be better ways of doing it but Iam new to vray also if you have a shaped front then applying the vray light material would be your better option The frosted material was from a free plug in from the link below http://www.aislan.com.br/download.htm Link to comment Share on other sites More sharing options...
godchi86 Posted July 4, 2007 Author Share Posted July 4, 2007 PAWUK said: I prefer the look of the vraylight (kept visible) I like the look of the vray light too, i was going to try the same thing when i get back to my work! How does this plug-in work? is it just a material? Cheers for the help! Link to comment Share on other sites More sharing options...
DisasterArea Posted July 4, 2007 Share Posted July 4, 2007 Image is looking good godchi86 That's good advice, link, and render there PAWUK Link to comment Share on other sites More sharing options...
PAWUK Posted July 4, 2007 Share Posted July 4, 2007 When you run the download it drops itself into the Material/map browser (mdsFrostedGlass) so you can select it just like vrayMtl or any of the others. It has a slider so you can change the frost opacity allows you to add bump and alter the IOR and effect shadows. It also gives you a chrome and aluminium material along the same lines but not sure about these yet. Link to comment Share on other sites More sharing options...
godchi86 Posted July 5, 2007 Author Share Posted July 5, 2007 PAWUK said: When you run the download it drops itself into the Material/map browser (mdsFrostedGlass) so you can select it just like vrayMtl or any of the others. I dont seem to be able to get it to work! Does it matter that i am using max 9? Link to comment Share on other sites More sharing options...
PAWUK Posted July 5, 2007 Share Posted July 5, 2007 godchi86 said: I dont seem to be able to get it to work! Does it matter that i am using max 9? No it shoudnt, we have 9 at work and thats the one I used to make the small illustration. Can you see the material when you apply it. Link to comment Share on other sites More sharing options...
