How to Rendering with many computers or net render ?
Antonius
  • 1 month later...
ok , after i spend my time scratching my head etc :D, i reading about backburner, i able to use net render. But there is something i want to ask,
i use net render in 2 computer but why the render process can work together in 2 computer?
first computer render, 2nd do nothing, then first computer do nothing , 2nd computer render.
can you guys give me any advice?
thx a lot guys
if you are trying to render only a single image via backcurner, you will have to split scanline. the split scanline option is available in the backburner dialog box that comes up. if you are only rendering a single image, this may be the reason multi-computer rendering doesn't seam to work for you. what happens when you try to submit an animation of say three frames? do both machines render then. also make sure the machines have a shared folder they can save the files to.
never used vray, but if you choose to do the split scanline option, if you don't have a GI solution already saved or locked for each computer to access and load, the split scanline option will probably not work for you as each machine will come up with a slightly different solution and the strips will not match perfectly.
