Sketch or Toon Renderer?
Munz
I searched the Knowledgebase for VIZ in Autodesk's Product Support website and I found this:
Obtain Vecta 3D MAX for Autodesk® VIZ 4 plug-in
Read the Disclaimer
Print
Applies to: Autodesk® VIZ 4
Published Date: 09/12/2002
Issue
The Vecta 3D MAX for Autodesk® VIZ 4 plug-in was not available for the first units of Autodesk VIZ 4 software that were shipped.
Solution
To obtain a copy of the Vecta 3D MAX for Autodesk VIZ 4 plug-in , please contact your Authorized Autodesk Reseller or Autodesk sales representative.
Why don't you try Illustrate! 5? It's great for toon renders.
You could, also, re-import your model into AutoCAD and take a hidden perspective. Then, you can paint it with Photoshop the way you like better.
You could also take a look at some other Photoshop techniques. I'm pretty sure there's something that'll fit your needs.
Rick
Look at SketchUP. You can export your model from Viz into SketchUP and get what it sounds like you are looking for. Variable lines with extensions and line weights.
I know it isn't free but if you learn fast, you can download the trial which is completely functional for 8 hours. Probably long enough for you to get what you need.
P.S. It really is a fun program and well worth the money IMO.
