Crashing Question.....
I have a file in 3dmax 9 which today has decided to crash every 30 sec or so. Was working on it yesterday and had no issue...... I have tried merging it into a new file, as well as merging only parts and leaving out others. Try as I might it keeps crashing. Is there some way that I can purge or audit a 3dmax file? thanks much
Hey Chad,
There's no purge as far as I know, but if you are suing DirectX as the Display, you might want to try and switch to OpenGL. It works for me for whatever reason. Just go to Customize/Preferences and you will find it there, You'll have to close and re-open max. Let us know if it works for you.
Best, D.
WOW.....
so I was able to change my graphic setup, however that crashes my computer everytime I open the problem file. I should say I am running Vista w/ Max 9 (I do have ALL of the updates and support packs)... I am going to trying running the file on an XP machine and see if that helps. Any other suggestions????
