navi Posted February 5, 2003 Share Posted February 5, 2003 I have some wall planes which are flat but are modelled in more than one piece (i.e. 3 horizontal planes making up a wall surface) When rendered w/ radiosity these different pieces which use the same material are easily visible by variations in colour tone. Any tips on how to remedy this problem? (it must be quite common) Link to comment Share on other sites More sharing options...
kainoa Posted February 5, 2003 Share Posted February 5, 2003 Howz about some renders? Although without seeing any images i can only guess what might be the problem. Try modeling the wall using just 1 plane as opposed to 3 since they're the same material anyway. Or try using a smaller mesh subdivision when processing the rad. Link to comment Share on other sites More sharing options...
navi Posted February 5, 2003 Author Share Posted February 5, 2003 here is an example of the problem. the inner panelling on the boards towards the centre of the image are all one material yet they display with various colour tones. the wood panelling trim is also showing similar results... Link to comment Share on other sites More sharing options...
abicalho Posted February 5, 2003 Share Posted February 5, 2003 Either process to a higher initial Quality amount, or select the object and apply Refine Steps to it. This variance happens because of the way Radiosity is computed in 3dsmax/viz. Alexander Link to comment Share on other sites More sharing options...
Cesar R Posted February 5, 2003 Share Posted February 5, 2003 regathering fixes this a lot of times Link to comment Share on other sites More sharing options...
nisus Posted February 6, 2003 Share Posted February 6, 2003 regather EATs time... set refinements to 20 or so... try it... next mesh divide... try that too... rgds nisus Link to comment Share on other sites More sharing options...
Cesar R Posted February 6, 2003 Share Posted February 6, 2003 I think regathering is worth the time on a render like being that it is interior with a huge sky light Link to comment Share on other sites More sharing options...
