cadjockey Posted July 9, 2007 Share Posted July 9, 2007 Hi all, I'm just starting out with viz using mental ray as the renderer. I am pleased with the results I am getting with just little tweaking. I am excited to know that future projects will get better and better. I have however hit a problem. I was playing around with a scene and it's settings. The camera is an exterior and uses the daylight system to light it with mrSun, skylight and mrPhysicalsky. I was getting ok results until I decided to try a shader. I didn't like the result so I removed it. Now every time I try to render the scene it suffers a fatal error and shuts down viz altogether. The error meesage I get from MR is : "max_base_blinnillumination"called mi_sample_light with unknown light tag 0x727 It seems to be only this scene that has the problem. I am able to render other scences no problem. Does anyone know what I have done and how I can rectify the problem? Thanks cadjockey Link to comment Share on other sites More sharing options...
fahtal Posted July 9, 2007 Share Posted July 9, 2007 i don`t know. maybe try to delete en setup the lights again. where did you put the light shader? Link to comment Share on other sites More sharing options...
hughie Posted July 9, 2007 Share Posted July 9, 2007 I seem to remember having a similar problem a while back, in the end I ended up mergering everything out of the scene except the object with the offending material. Link to comment Share on other sites More sharing options...
cadjockey Posted July 10, 2007 Author Share Posted July 10, 2007 Hi guys, Thanks for the reply. I think I fixed the problem. I changed the sky to mrsky instead of skylight. It rendered fine after this. The more I learn about this software the more I realise what I do not know. cadjockey Link to comment Share on other sites More sharing options...
