mare96 Posted July 10, 2007 Share Posted July 10, 2007 what are the advantages of using vray sun/sky/pysical cam in conrtast with a simple target light?i tried to render an exterior scene with both of them and had the same results.the problem was that in the first case there were many and difficult settings. so...? Link to comment Share on other sites More sharing options...
chiquito Posted July 10, 2007 Share Posted July 10, 2007 OPTIONS. I would say that is the advantage. I believe its the control you get with one and the other those difficult settings are the ones that will give you the exact shot you are looking, its like comparing a professional photo camara with a cheap disposabel one, of course you can get exelent results with the cheap camara and crappy results with the good one. But the difference, at least for me is getting to know why are there some many options, (option and not difficulties) on the other. Try playing wit some variables and try matching them with a target light... you will see that even if its hard to get the precise setting you are looking for, eventually you will be much more analitic on the look and mood you are trying to get. For me its still har to get tyhere. but I rather see it as a possibility and noy an anoying task Link to comment Share on other sites More sharing options...
ttzol Posted July 10, 2007 Share Posted July 10, 2007 Ισχυει αυτο που γραφει ο φιλος απο πανω . Επιπλεον δοκιμασε να συγκρινεις το focal imaging της απλης καμερας με την vray και θα καταλαβεις . Θα σου σπασει τα νευρα στην αρχη αλλα οταν το μαθεις , δεν θα ξαναγυρισεις πισω Link to comment Share on other sites More sharing options...
Tommy L Posted July 10, 2007 Share Posted July 10, 2007 Its all greek to me. Link to comment Share on other sites More sharing options...
Sawyer Posted July 10, 2007 Share Posted July 10, 2007 Its a different workflow and a different way to approach your work. I don't think anyone should think that it is a mandatory process it is a new tool. One of the 3das Brian's said it best if you are not familiar with a regular slr camera and how it works you may find it is a workflow that you don't want to learn. Personally I believe many architectural photographers would love all of the work arounds we have to get good lighting. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted July 11, 2007 Share Posted July 11, 2007 Its all greek to me. :D Link to comment Share on other sites More sharing options...
mare96 Posted July 11, 2007 Author Share Posted July 11, 2007 Ισχυει αυτο που γραφει ο φιλος απο πανω . Επιπλεον δοκιμασε να συγκρινεις το focal imaging της απλης καμερας με την vray και θα καταλαβεις . Θα σου σπασει τα νευρα στην αρχη αλλα οταν το μαθεις , δεν θα ξαναγυρισεις πισω my friend here talks about comparing focal imaging of the default target camera and the vray camera.its quite difficult in the beginning but its a powerfull tool if you learn how to use it. so...how to use it?? thanx for the posts Link to comment Share on other sites More sharing options...
