jman0 Posted July 10, 2007 Share Posted July 10, 2007 Hi i just wonder how someone would go about creating contours using existing survey data in a CAD file. I know how to create a polyline obviously...i suppose what i'm asking: is there a rhyme or reason or method to employ when using survey data like that contained within the cad file attached? What you you personally do, to get contours from this information? Link to comment Share on other sites More sharing options...
neko Posted July 10, 2007 Share Posted July 10, 2007 well, the fact that most of the contours aren't drawn yet means you have to draw your own based on the data provided. the data is all 2D, but the few contours that are drawn are at the correct elevations (3D). did you draw those ? basically draw your own polyline paths and then move them in the Z axis to their correct elevation (it is actually a pretty level site, isn't it ?). after that you can loft them into a solid terrain base, or use rulesurf/edgesurf for a surface mesh......depends what you want to do with the project in terms of visualization. hope that helps paul Link to comment Share on other sites More sharing options...
chiquito Posted July 10, 2007 Share Posted July 10, 2007 What I did when I needed it wast to draw splines in autocad, and latter, elevated then to the corresponding height, copy the spline and adjust it either editing the splines vertices or hight, latter, exporting to max each one of this splines as a layer, and using a terrain modifier or a nurbs surface, that usaulli gave me the resultas I needed. Good luck, Martin Link to comment Share on other sites More sharing options...
neko Posted July 10, 2007 Share Posted July 10, 2007 good point - if you have MAX/VIZ and are planning on using it for the project, it is easier to create the terrain there, rather than autocad. i just assumed you wanted an autocad solution since that is where you posted. you can still draw the contours in autocad and link/import to VIZ/MAX Link to comment Share on other sites More sharing options...
Claudio Branch Posted July 10, 2007 Share Posted July 10, 2007 is there a rhyme or reason or method to employ when using survey data like that contained within the cad file attached?..to get contours from this information? Typically, I receive survey data that has been formatted into a point file or into 3d contours. I take that data and triangulate it into a TIN for my terrain geometry. I do all of my terrain modeling (roads, parking lots, bodies of water) in AutoCAD and then finish it up in Max. Link to comment Share on other sites More sharing options...
jman0 Posted July 11, 2007 Author Share Posted July 11, 2007 sorry i should clarify, i'm just asking about creating the contours. I'll use MAX or Sketchup to generate the actual polys. I suppose my difficulty is the scattered nature of these elevation points within that CAD file. Contours don't look scatter-gun like that, so i suppose i must figure out a logic to drawing contours that resemble...well contours lines. Link to comment Share on other sites More sharing options...
visualasylum Posted October 16, 2007 Share Posted October 16, 2007 I have done this many times as well. I pay my surveying company to generate the contours for me, he uses a program called Surfer and the programs creates nice contours. Then when I get the CAD file I make sure I make all the contours a polyline and I import these into MAX on same scale and unit settings. In Max I generate the Terrain and then I export this to 3ds or DXF, and re-import back to CAD. For visualization something I import to sketchup to visualize the building on the topography of the property. There's also a very cool plugin for AutoDesk Architecture or Cad that is called Terrain which will generate the topography based on points. Kind Regards, Greg Lacle Link to comment Share on other sites More sharing options...
jman0 Posted October 17, 2007 Author Share Posted October 17, 2007 Terrain plugin for CAD seems nice and quick. To create a mesh at least. And Surfer looks fantastic generally, but very expensive. Are there any other quick and easy plugsins or programs that will interpret survey data in CAD and generate contours easily and effortlessly? Link to comment Share on other sites More sharing options...
narendra1987 Posted June 11, 2011 Share Posted June 11, 2011 i want producere to convert levels in auto cad. given the brief data Link to comment Share on other sites More sharing options...
samah Posted April 15, 2012 Share Posted April 15, 2012 Mr. Kumar You can use auto-it to create a command script ..its like creating a software to overlap other software..autoit style + you need uploading of layers of data of same height 1 by one --use auto-it script to select their location 1 after another under polyline function ..once you complete the 1st contour whatever copmmand (next height contour)--you can create a loop too. to completely automate the process. Link to comment Share on other sites More sharing options...
muhammadadeel Posted July 29, 2012 Share Posted July 29, 2012 My Dear, Send me this data bye mail for contour. adeelmuscat@yahoo.com And don't worry about this, it's very minor job. Take care Link to comment Share on other sites More sharing options...
muhammadadeel Posted July 29, 2012 Share Posted July 29, 2012 My Respected Dear, Why are you send wrong message to some one, did you mansion witch software he will used and what's steps? so plz don't make confuse to others. Thanking you, Link to comment Share on other sites More sharing options...
muhammadadeel Posted July 29, 2012 Share Posted July 29, 2012 Dear Viewer, Adeel hear for a waiting to help you in road highway projects. any one can contect me. See you. 00968-94036921 Link to comment Share on other sites More sharing options...
sanjurathod Posted October 20, 2012 Share Posted October 20, 2012 friend file not download Please send file as My E-mail ID- sanju2323@yahoo.co.in Link to comment Share on other sites More sharing options...
egeomatemagazine Posted May 15, 2013 Share Posted May 15, 2013 I hope this help, is explained step by step http://egeomate.com/contours-from-polylines-step-2/ Link to comment Share on other sites More sharing options...
anujshukla Posted November 21, 2013 Share Posted November 21, 2013 hello I am anuj i want some help to create contour maps using autocad LT if any body have any suggestion please give me Link to comment Share on other sites More sharing options...
hrishikeshp Posted March 1, 2014 Share Posted March 1, 2014 Hi people, I have 2d contour with numbers. How can i develop the 3d terrain or arrange contour lines in z axis accurately with the help of 2d (flat contour). Please help me..!!!!! Link to comment Share on other sites More sharing options...
ranjankumar Posted April 14, 2014 Share Posted April 14, 2014 Hi. I m ranjan Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted May 6, 2014 Share Posted May 6, 2014 If you have to trace contours, don't draw them flat then move later. Draw them at the correct elevation to begin with. Use command shortcuts to name elev and pline to something you can do easily with one hand. I'm a left mouser so maybe I'd use L and P while doing contours. You righties might want Q and W. Whatever. The elev command is a little tedious because you have to hit enter twice because it asks for thickness. Write a quick lisp to hit enter for you. Maybe later I'll throw together a suite of helpful lisps to increment and decrement the elevation by a fixed amount. Hey, wouldn't it be clever if it noticed the majors and changed layers automatically. Link to comment Share on other sites More sharing options...
dannybissoondath Posted October 2, 2014 Share Posted October 2, 2014 hi morning could some one help me to convert auto cad drawing into contours drawing Link to comment Share on other sites More sharing options...
