First interior using MRay...
portisgreg
Hi Greg,
No a MR user myself, but it seems you have some issues with your cornice. Could be co-planar faces. If not try adding a smooth modifier.
PS Who are you working for in St.Albans................I live in Harpenden and spent many years working in St.Albans.
Trev
You seem to have an unnatural light hitting the ceiling, are you using Sky light? Most of the light in your scene comes from above and hits your floor, it is the floor that will illuminate the rest of your scene so a "little" color bleed will help tie this together. You may want to create a plane on the exterior to block the light from below from hitting the ceiling. I would do the exterior background in PS so you can control the brightness and saturation. Your wood texture need some luv....
As mentioned by Rob the wood needs some attention too. Improvements could be made using a better resolution and quality initial texture (especially for the 'red' wood @ the bar). Trying to make the gain match with a natural direction for construction would help bring the wood out.
-Andrew
