shikodesign2000 Posted July 21, 2007 Share Posted July 21, 2007 Hi, I have a problem in my present project, it's an interior animation of an appartment, I'm using the famous way: calculating Light cache+Irradiance map for the whole animation then rendering the final sequence. My problem is: I find a lot of distortion in the final video, I don't know why? The resoultion is 640*480, the compressor is "Cinepak Codec by Radius" The image sampler is: Adaptive subdivision The antialising filter is: Catmull-Rom I think the solution is in the AA filter, and I must use blurring filter, if this true, can I know what is the best blurring filter? Video or Area? or something else?? And is there any other options are important in rising interior animation generally.confused: Link to comment Share on other sites More sharing options...
Scott Schroeder Posted July 23, 2007 Share Posted July 23, 2007 I wouldn't use the cinepak codec, I bet that's the reason you're getting a lot of distortion. If you can, render out each frame as a .png or .tga then put those through software like combustion or after effects. If you can't or do not have that software, try the windows media 9 codec. I've generally found that it's better than the cinepak, though you still will get some compression issues. Link to comment Share on other sites More sharing options...
shikodesign2000 Posted July 24, 2007 Author Share Posted July 24, 2007 Ok, I rendered 150 frames as test with .png extension, then I merged them in "combustion" into 1 video file with extension .mov for quick time player. The quality is very good , but the file size is very big: 119 mb, I think the solution is to compress this file:confused: or I'm wrong?? and I had to produce the sequenced files in "combustion" to another extension, (not .mov)?? What have I do to produce a reasonable file size with good quality?? Link to comment Share on other sites More sharing options...
Tommy L Posted July 24, 2007 Share Posted July 24, 2007 Use divx Link to comment Share on other sites More sharing options...
mfured20 Posted July 25, 2007 Share Posted July 25, 2007 i like the option of buying quicktime pro, and using it to stitch together individual frames. you can use import an image sequence and export it out to specific parameters. I tend to use the H.264 quicktime compression, it is excellent. also, since it saves out as a quicktime movie, it can be viewed on most computers. Apples come with quicktime installed, and most PCs have it, altho i have found that some of my client's workstations wont allow quicktime movies, they that doesnt happen often. you can also save out to H.264 compression thru Adobe Premiere, but i havent really used it that much in all honesty. Good Luck! Link to comment Share on other sites More sharing options...
shikodesign2000 Posted July 26, 2007 Author Share Posted July 26, 2007 Do you mean that this way can produce high quality with reasonable file size?? Link to comment Share on other sites More sharing options...
Tommy L Posted July 26, 2007 Share Posted July 26, 2007 Depends what you mean by 'high quality' and 'reasonable' filesize. If you compare anything to uncompressed you get a reasonable filesize. So....have you tried divx? Link to comment Share on other sites More sharing options...
shikodesign2000 Posted July 28, 2007 Author Share Posted July 28, 2007 I just use Combustion to import (the 150 .png stills) then merge them together and specify divx as codec exporting, but the result is the same as I rendered them in max with divx, very low resolution. I just liked the quick time quality, but the problem is it's very big size, 95 mb for just 150 frames, I have about 5500 frames for all the appartment!! I'll try the h.264 quick time compression and see if it'll work or not. Link to comment Share on other sites More sharing options...
shikodesign2000 Posted July 28, 2007 Author Share Posted July 28, 2007 I just used Combustion to import (the 150 .png stills) then merge them together and specify divx as codec exporting, but the result is the same as I rendered them in max with divx, very low resolution. I just liked the quick time quality, but the problem is it's very big size, 95 mb for just 150 frames, I have about 5500 frames for all the appartment!! I'll try the h.264 quick time compression and see if it'll work or not. Link to comment Share on other sites More sharing options...
shikodesign2000 Posted July 28, 2007 Author Share Posted July 28, 2007 I found that when I use Quick Time pro (the last version), I can export the big (quick time file 119 mb) which I made it in combustion and produce very similar quality and very good size 4 mb, a very few differences between the 2 versions, I think this's the best solution, if anyone knows better solution let me know. Link to comment Share on other sites More sharing options...
