innerdream Posted July 23, 2007 Share Posted July 23, 2007 I have SU free and I'm trying to make a tube stair rail going down a flight of stairs with the tubes spaced about 10" apart. I tried the follow me tool but it won't follow all of the splines. It stops at the intersections. Any tutorials on how to make rails? Thanks. Link to comment Share on other sites More sharing options...
bytor Posted July 30, 2007 Share Posted July 30, 2007 Innerdream, No tutorial here, but - try this. Create the wireframe (centerline of rail) of your railing layout and running a ruby script called tubealongpath - which is attached in a zip file. This should get you close to what you want - corners may look goofy unless you radius them. hth.............Bytor Link to comment Share on other sites More sharing options...
innerdream Posted July 30, 2007 Author Share Posted July 30, 2007 Innerdream, No tutorial here, but - try this. Create the wireframe (centerline of rail) of your railing layout and running a ruby script called tubealongpath - which is attached in a zip file. This should get you close to what you want - corners may look goofy unless you radius them. hth.............Bytor Thank you sir. I'll give it a try. Link to comment Share on other sites More sharing options...
