turbo2000 Posted July 25, 2007 Share Posted July 25, 2007 Hi can someone help to create a wall material like this in black http://whisky-aps.dk/SiteConnect/userimages/-722594502 If it's to any help, here are some measurements: http://www.corusgroup.com/en/company/divisions/distribution_building_systems_division/corus_distribution_and_building_systems/cbs_nordic/wall_cladding/trapezoidal_profiles/#31008 Link to comment Share on other sites More sharing options...
RTurner Posted July 25, 2007 Share Posted July 25, 2007 Are you modeling the ridges or using bump map? If you can afford it and quality matters, model the ridges, otherwise it will look very flat at the edges. Edit Poly is your friend. Link to comment Share on other sites More sharing options...
diegofer_9 Posted July 25, 2007 Share Posted July 25, 2007 turbo2000, I think it depends how close you get to see this material. If it's very close to your camera, I would definitely model it. If it's really far, you can get away with a bump material made of black and white lines, to simulate the ribs, or even with displacement to get more detail. But again, you should think about it in terms of how much detail do you want. Link to comment Share on other sites More sharing options...
turbo2000 Posted July 25, 2007 Author Share Posted July 25, 2007 Okay thank you both, i am not the big modeller so i guess i maybe have to make a bumpmap for it... Link to comment Share on other sites More sharing options...
