STRAT Posted July 26, 2007 Share Posted July 26, 2007 Hi chaps Just received my new Formac mini disk in the post http://tinyurl.com/3aep6w it's a native mac thing which needs formatting specifically to work on Win XP. The manual is shite. All it says is... "to format the disk (NTFS) use the disk management utility in windows to configure a device character" this is kinda sparse info and i cant seem to do it. it's easibly do-able, i just dont know how to do it using the windows disk management system as it suggests. any help please? thanks Link to comment Share on other sites More sharing options...
AJLynn Posted July 26, 2007 Share Posted July 26, 2007 Control Panel, Administrative Tools, Computer Management has a Disk Management section that's for this kind of thing. It would make you use NTFS - Windows imposes a 32GB limit on FAT32. A better option, if you have access to a Mac, would be to use the Mac's Disk Utility to format the disk in MS-DOS mode - it lets you format a volume of that size in FAT32 which makes it read/write on MacOS and Windows. Link to comment Share on other sites More sharing options...
STRAT Posted July 26, 2007 Author Share Posted July 26, 2007 Andrew, i know about the "Control Panel, Administrative Tools, Computer Management has a Disk Management section that's for this kind of thing." bit, but then what? how do i format from there? Link to comment Share on other sites More sharing options...
JamesTaylor Posted July 26, 2007 Share Posted July 26, 2007 if the drive shows up in the disk management section, i think you can simply select it, right click on it and choose format (you may need to delete the existing partition first, it should also be an option avaible under right click again)... that should start the process and you'll be able choose the appropriate settings in the dialog box Link to comment Share on other sites More sharing options...
STRAT Posted July 26, 2007 Author Share Posted July 26, 2007 thank you fellers. all is good Link to comment Share on other sites More sharing options...
