Tim Nelson Posted July 29, 2007 Share Posted July 29, 2007 Is there any difference between the two, other than the price? I couldn't see any. Link to comment Share on other sites More sharing options...
AJLynn Posted July 29, 2007 Share Posted July 29, 2007 The QX has the Kentsfield XE core as opposed to the regular Kentsfield, see this. The main advantage I can see with the XE is the unlocked multiplier, which allows some interesting OC'ing tricks like dropping the multiplier to run the RAM faster with the same CPU speed. Link to comment Share on other sites More sharing options...
Tim Nelson Posted July 29, 2007 Author Share Posted July 29, 2007 Ahh I see. Wow they really get you there. I have been using the Qx6700, and the unlocked multiplier does make it super easy to overclock. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 1, 2007 Share Posted August 1, 2007 ^ What max stabile speed did you reach whit unlocked QX6700? For 24/7 working? Link to comment Share on other sites More sharing options...
Tim Nelson Posted August 2, 2007 Author Share Posted August 2, 2007 ^ What max stabile speed did you reach whit unlocked QX6700? For 24/7 working? I have ours at 3.2, which was the only test I ever tried. I'm sure it can go much higher though. Link to comment Share on other sites More sharing options...
AJLynn Posted August 2, 2007 Share Posted August 2, 2007 Crank that up, we all want to know Link to comment Share on other sites More sharing options...
Tim Nelson Posted August 2, 2007 Author Share Posted August 2, 2007 Crank that up, we all want to know Ok! Maybe I'll try 13x and see what happens. Link to comment Share on other sites More sharing options...
