large visual crashes
DaveP
Please help, the attached visual renders ok at 1500px x 1500px ( vray1.5 and max 9). As soon as we go above this level the image crashes. I have tried removing shadow recieving form the plants, splitting the image up in backburner, lowering the LC. Backburner just reports back unexpected error and max 9 does not give any clues to the problem either.
Any ideas would be greatly appreciated.
Kind regards
David
well since its a relatively simple scene, i would suggest checking your system resources. Does it crash as a result of memory consumption? (check through Task manager).
Try turning off Vray displacement if used on Grass (since it consumes up a lot of memory)
Another solution that might help is the /3GB switch in boot.ini file.
read up more about it here:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=14564
hope this helps
Amer
Sound like a memory issue to me too. Do you have RPC's in there? They can cause this I find. Maybe split the image up further too, ie foreground plants seperate, people seperate etc, then layer it up in PS. This will give you more control too :)
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=19643&start=0&postdays=0&postorder=asc&highlight=memory
you will find:
(*) Make sure you are using the V-Ray VFB;
(*) In the Common tab of the Render scene dialog set the resolution to something like 320x240;
(*) In the V-Ray VFB settings, turn OFF the "Get resolution from Max" option for the VFB, and specify the actual resolution that you need;
(*) Turn off the "use memory frame buffer" option;
(*) Turn on the "write raw image file" option and specify a .vrimg file in the field below it.
(*) Turn on the "generate preview" option.
(*) After the rendering is complete, use the vrimg2exr tool to extract the render elements as .exr files. You can find the vrimg2exr tool in the Start menu > Programs > Chaos Group > V-Ray for 3dsmax > Tools. There is also a GUI for it posted in the off-topic section of the forum, I think.
Also, the use of dynamic memeory
