Rendermedia Posted August 6, 2007 Share Posted August 6, 2007 Hi All, I am working on a Verified View for a client, the client has provided me with 4 camera positions such as X,Y & Z values, The problem I have is that when placing these into my scene the cameras do not match up with the development (which I am led to believe is in the correct space XYZ) the figures from my client for 1 camera is as follows Short Range B - x624523 y234274 z23.6mAOD however if I select the bottom corner of a building near this camera I have a value of x1364.323 y3736.223 z23.25 there is no decimal point in the camera values my client gave and I would not expect one as they are using Topographical data and not Max, however these values which i am told are correct are too long at 6 digits, sorry to give you a Vulcan mind meld so early on a Monday morning. Kind Regards Mark Link to comment Share on other sites More sharing options...
colinsmith Posted August 6, 2007 Share Posted August 6, 2007 Sounds like the CAD survey is on it's own grid, the co-ordinates from the client sound like national grid numbers, while the development ones are not. Maybe see if the surveyor can give you national grid cooridnates for his stations? Otherwise I would guess you are looking at pulling grids from OS maps for a few building corners (survey grid might be rotated too) and fitting as best you can. Link to comment Share on other sites More sharing options...
