Billabong Posted August 6, 2007 Share Posted August 6, 2007 I'm trying to make just a standard illuminated light from a cieling,kind of like a light bulb. I have tried creating just a vray light material and add a frosted glass to either the color channel or the opacity one, but it wont allow it and if i just use a vray light material, it looks to flat, i also tried the fresnal falloff in the light material, but that didnt look so good either, any suggestions? Link to comment Share on other sites More sharing options...
FancyPants Posted August 6, 2007 Share Posted August 6, 2007 Try playing with a VRAY Blend material, with the base being a Vray Light Mtl, and the blend a Vray Material.. play with the mix levels and highlight glossiness.. keep it simple at first, and add more complexity only if you need to. Link to comment Share on other sites More sharing options...
aaron-cds Posted August 6, 2007 Share Posted August 6, 2007 Use the vray2sided material with a cylinder or plane behind the lense with a vraylightmaterial applied. You can use a vraylight but your render times will jump up. Link to comment Share on other sites More sharing options...
Billabong Posted August 6, 2007 Author Share Posted August 6, 2007 Thanks Justin that was exactly what I needed Edit: opps, didnt see your reply Aaron ill try yours as well, thanks again guys Link to comment Share on other sites More sharing options...
aaron-cds Posted August 6, 2007 Share Posted August 6, 2007 Try playing with a VRAY Blend material, with the base being a Vray Light Mtl, and the blend a Vray Material.. play with the mix levels and highlight glossiness.. keep it simple at first, and add more complexity only if you need to. I always wondered how to get a vraylightmaterial with a bitmap to be reflective. Thanks! I assume this is the way to do it. Link to comment Share on other sites More sharing options...
jophus14 Posted August 7, 2007 Share Posted August 7, 2007 That's a great tip FancyPants. Thanks. Link to comment Share on other sites More sharing options...
