louis.cho Posted August 7, 2007 Share Posted August 7, 2007 Hi I am facing a problem with a Mental Ray Sun & Sky system. It's the first time I use that kind of lights, I usualy use a skylight+HDRI with a MR Spot. The scene is build for both exterior and interior animation. My problem is that there seems to have no shadow cast by the sun, there is only a light and diffuse shadow. The shadow option is turn on with defauly settings. I would love to see a precise and contrasted shadow, how can I do it? EDIT: after some others test(push up Sun multiplier to 10 or turn it off) , it's seems that it's the MR Sun who doesn't affect the scene. I can't understand it. any ideas? thanks Link to comment Share on other sites More sharing options...
Justin Hunt Posted August 7, 2007 Share Posted August 7, 2007 Keep the MRsun at 1 and use exposure control What happens if you turn in the "Inherit from Sky"? Dumb question but is the building set to cast shadows? JHV Link to comment Share on other sites More sharing options...
louis.cho Posted August 7, 2007 Author Share Posted August 7, 2007 The building can cast shadow(not a so dumb question) and the ground can receive. Inherit from Sky doesn't change anything. the problem is that the Sun doesn't work at all. I can turn it completly off and it's make no change. how can I thurn the sun On? I made a test, a new scene, simple geometry with a single MR Sun. Physical sky to see the background. You can clearly see that the scene is black, the Mr Sun don't light at all. Link to comment Share on other sites More sharing options...
louis.cho Posted August 7, 2007 Author Share Posted August 7, 2007 Resolve, don't know why:confused: Link to comment Share on other sites More sharing options...
Justin Hunt Posted August 8, 2007 Share Posted August 8, 2007 Tried your file, had the same problem. So I deleted the sun and made a new one. All working now JHV Link to comment Share on other sites More sharing options...
louis.cho Posted August 8, 2007 Author Share Posted August 8, 2007 thanks for checking i had tried this but didn,t worked. I had to made a new scene from another computer and bring it here... thanks Link to comment Share on other sites More sharing options...
