salf Posted November 10, 2003 Share Posted November 10, 2003 I think its called VRLM. I wanna be able to move around a rendered image, for instance i have the render image of a bathroom, i wanna click on the picture and do a 360° turn around the picture with my mouse. How to do this type of work? WHats the software i need, or pluggins? Currently use AutoCAD and then 3d VIZ. Thanks, sorry for the newbie question. Link to comment Share on other sites More sharing options...
vizwhiz Posted November 10, 2003 Share Posted November 10, 2003 hi There Salf, you can use VIZ to make a panoramic Image under Utilities (i Think) there is a button for Panoramic rendering in VIZ 3 (VIZ 3 is different that VIZ 4) This will create a 6 sided Image(s) that will be seamed together to produce a ".pan" file i Think that the Camera has to have a 60 degree angle of view set before you do the renderings **** let me know if This helps VRML allows free movement within the Image a Panoramic file allows you to turn 360 in it not sure what is the best VRML package to use hopefully someone else will have more Info on That **** Thanks Randy Link to comment Share on other sites More sharing options...
tcorbett Posted November 10, 2003 Share Posted November 10, 2003 VRML (Virtual Reality Markup Language) files can be produced directly from VIZ through the Export function. The *.WRL file can then be opened with a web-browser with a VRML plug-in installed. Parallel Graphics "Cortona" viewer (http://www.parallelgraphics.com) is available for free, and tends to be the most stable. Although I agree, what you've described sounds like a panoramic VR file, which VIZ/Max can also create. Link to comment Share on other sites More sharing options...
