Chad Warner Posted August 7, 2007 Share Posted August 7, 2007 I ran through a gamut of threads and suggestions here and on the chaos group site, and finally figured out some settings for getting rid of noise that worked, which are as follows: Adaptive QMC, Quadratic filter, IR map set to "low" with 20 subdivs and 30 samples No secondary bounce. rQMC sampler: adaptive amount set to .85, noise threshold at .008, min samples 8, global mult. @ 1. adaptive rQMC image sampler, min 1 max 5 use QMC sampler thresh is checked. These settings were working fine with a standard Target direct light. As soon as I switched to a Vray sun, all the noise came back. Does anyone have some suggestions for settings that won't kill me at render time? Thanks, Chad Link to comment Share on other sites More sharing options...
