First exterior image
craig.t
Hi All,
this is my first serious bash at a simple exterior image using Max 9 + Vray.
It was modelled in SketchUp and then exported into max. for the final render.
I have been messing with it for ages so decided to put it up here for your review and hopefully some comments to help me improve it.
Many thanks in advance
Craig
hi craig, long time no see :)
nice pic, only i'd watch the radiosity levels - it all looks too green. and as mentioned, take a closer look at your texturing. it's all very CG and toystoryish, and you'd see a nice sharp defined roof tile in reality too. from this distance they might be worth an arrayed model instead of a texture.
also, what your contrasts. it's looking a tad flat, especially with that nice blue/cloud backround looking dulled out.
The image needs a little tweaking perhaps more varied colourful vegetation and try to breakup the repetition. Otherwise it's looking good. Architectural though, the architect should be fired/deported/lynched. Its not a good idea to have the stucco go all the way down to grade at least not in temperate environments. Introduce a 3' high stone/brick base with a 3" precast conc. ledge all the way around the house. Add a circular vent or window on the gable face to fillup the empty space.
unfortunately those comments wont stand much in the UK. the design Craig has drawn is a normal common scheme over here. you usually add a 2 or 3 brick course off the floor before the render for the damp proof course, which he's done. and again, a blank gable wall is also common place in housing schemes such as this :) (and if anything, it almost certainly wouldn't be circular)
it's interesting to hear the differences different countries use in design schemes
Hi Strat,
thanks for the comments i'll play around with it when i have time,
THEPRAYINGMANTIS
Unfortunatley exactly as strat has said it's a typical housing developer house type.
P.S. Strat i hear that exciting times are ahead for you!
Craig
I speak from experience guys. I don't just draw/render pretty pictures, I actually design houses. If I were to design a house to be situated in the UK with its high annual precipitation rate, I would provide a masonry base to protect the stucco from moisture damage. Now, if this house were to be situated in a location with low annual precipitation rates like Aruba or the Arabian Desert then that’s a different story.
Cheers
Cheers
which is what he's done :) a 2-3 layer of bricks off the ground before the stucco is standard procedure in the uk i assure you. it's all thats needed and required. we dont suffer problems you seem to indicate. (hense the regulations) :)
