alfienoakes Posted August 8, 2007 Share Posted August 8, 2007 Seems like an age since I last posted anything..! Well, I have been battling with LWF, and Vray 1.5 and all its physical stuff... cameras, sun, daylight, environment etc.. So, here is something that I used the Sun system / physical camera on.. but unfortunately it missed the LWF boat.. Still a bit of post to do, but, would welcome comments on any improvements that I don't know about in all singing / dancing Vray 1.5.. Cheers Link to comment Share on other sites More sharing options...
Q-Bix Posted August 8, 2007 Share Posted August 8, 2007 Looks ok, Personally i would make the shadows a little softer. If you increase the Vray Sun 'Size Mulitiplier' it should do the trick. Link to comment Share on other sites More sharing options...
innerdream Posted August 8, 2007 Share Posted August 8, 2007 Looks washed out, I'd back off the intensity a bit. Link to comment Share on other sites More sharing options...
alfienoakes Posted August 8, 2007 Author Share Posted August 8, 2007 Cheers so far.. Daniel, I always thing that bright sunlight shadows, externally, generally maintain their intensity, for large objects anyway. If it were say, a window mullion, then that would become softer, the further away from the shadow casting object. Which bits do you think need to be softer..? Robert, It doesnt look too bad on my monitor.. It is quite a bright scene, but it certainly doesnt look washed out. It looks fairly contrasty.. I will have a look at it on some other monitors.. The brick does look a little washed out though.. Maybe I will have a tweak at that. The renders are very pastel.. Client requirements Cheers Link to comment Share on other sites More sharing options...
innerdream Posted August 8, 2007 Share Posted August 8, 2007 hi, It's a nice image. What I'm seeing is that your left wall and front wall are the same value and it is making the image look flat, also there is not much definition.shading to the surfaces of the building which is why it is looking washed out to me. I'm on a new Macbook. Link to comment Share on other sites More sharing options...
alfienoakes Posted August 12, 2007 Author Share Posted August 12, 2007 Cheers guys.. I will be having another look at this one, once we get some comments back from the client.. May even "water colour" it in P'shop... cheating I know.. but depends what they want.. Next time, it will be in Finished work..! Link to comment Share on other sites More sharing options...
luckysaqi Posted March 1, 2011 Share Posted March 1, 2011 1st. never place the sun right behind the camera but also try to place the about about 45deg side from the camera angle and at the height of 60deg. it gives more contrasty results Link to comment Share on other sites More sharing options...
