hooman_71 Posted August 8, 2007 Share Posted August 8, 2007 hi there I'm compositing a tga sequence in adobe preimiere, but i see little interrupts when I play the output file. (even when i render work area in application ) I used 25 fps in pal system. i set the speed for each section manually. may this cause the little interrupts? thanks in advance for ur posts. Link to comment Share on other sites More sharing options...
