Neil Woodhouse Posted August 8, 2007 Share Posted August 8, 2007 Greetings all, A very simple question. I have been asked to produce a couple of viz's as wireframe images. Any idea how this is done using VRay. I've looked but can't find anything. Regards Neil Woodhouse Link to comment Share on other sites More sharing options...
hughie Posted August 8, 2007 Share Posted August 8, 2007 Got a simple answer Check out V-ray Toon effect http://www.vrayelite.com/basic.htm#6 Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 8, 2007 Share Posted August 8, 2007 vray edgetex material Link to comment Share on other sites More sharing options...
Neil Woodhouse Posted August 8, 2007 Author Share Posted August 8, 2007 Hi, Sorry guy's, but the suggestions don't do what i want to do. Looks like i'm going to have to go to the default scanline renderer and tick the 'Force Wire Frame ' box. That does what i want it to do. Unless of course there is another way with VRay. Cheers Neil Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 8, 2007 Share Posted August 8, 2007 Are you sure applying the VRayEdgeTex map doesn't do what you want? Apply it to the diffuse channel and that's all. Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 8, 2007 Share Posted August 8, 2007 Are you sure applying the VRayEdgeTex map doesn't do what you want? Apply it to the diffuse channel and that's all. you can make it hidden line style wireframe or traditional wireframe by either setting the material to white (or any colour you choose) or by making the base material transparent Link to comment Share on other sites More sharing options...
