marcbon31 Posted August 8, 2007 Share Posted August 8, 2007 Hello please a need a little help, im modeling a surface in max and would like to know if theres a way of constrain the movement of the vertex in the direction of the normal of the mesh, is a polymesh by the way.... thanks Link to comment Share on other sites More sharing options...
moodo Posted August 8, 2007 Share Posted August 8, 2007 a way to reaching this is to use the autogridfunktion. create a box with autogrid checked, then go to the area of your polygon and raise your box. than you have a established a local grid pick your box under coordinat system then constrain your desired axis. i guess it works... Link to comment Share on other sites More sharing options...
