render settings
louis.cho
I am currently in testing some renders settings for my animation. It's a 600 frame anim at 720x350.
I made theses tests and here the result
FG low, aa 4-16 --- 6m28
FG low, aa 1-16 --- 6m15
FG Draft, aa 1-16 --- 4m35
FG low, aa 1/64-1/64 ---2m12 ---write FG
FG low, aa 4-16 --- 6m36 --- Read FG
FG low, aa 1-16 --- 6m32 --- Read FG
FG Draft, aa 1-16 --- --- Read FG map low settings
is it correct? The result is very very similar between all renders. My conclusion is that Fg draft and aa at 1-16 will be very good. 4min35 per frame.
Any idea?
If you are using the proper workflow of freezing the FG the it will have little to no effect on the final rendertime regardless of Low or Draft.
AA will have a great effect. 1,16 is fine for stills but too low for animations especially if there is alot of fine detail. 4,16 is better.
I am doing an animation right now and have found that FG setting even lower than draft work better than low. I also use AO to bring out the detail
Here is a frame of the animation
JHV
Absolutly, in fact if you are going the low FG route then Ao in essential
I am using these settings
Density 0.2
FG rays 400 (can be less)
Interpolate 100
Bounces 3
Trace depth 30
This is giving me a nice clean FG that render quickly for a very detailed scene. The colour bleed is more a colour wash and the AO brings out the shadow detail. There is no crawling or blochyness.
The animation starts outside and moving inside, walking down a long mall. My lighting rig isnt normal though. I am using Output shaders (self illumination) to light the interior and the MRsun and Skt system. There are also a few omnis to highlight important areas. So in all there are only 10 lights.
JHV
Ok, it's seems to be a good pipeline, I must give a try.
Correct me if I am wrong but what I know about AO(from still images) is that it's a completly different render pass. So I must re-render all the frames with the material overdrive with the AO in it? Is there another way?
just to clarify: when you say 'AO is Built in', do you mean that you don't need to make 2 render pass anymore?
If no, what I understand is that I need to make another render with an AO material and mix this render in a software like combustion, no?
thanks
I mean that if you look under the Special Effects tab of a Arch&Design material you will see Abient Occlusion with settings.
So no need to render a separate pass for AO
Might I suggest you take some time and read the manual with regards to the A&D shader. It will give you a fuller explination
JHV
