chrisclocher Posted August 8, 2007 Share Posted August 8, 2007 So I am trying to create a skydome (Viz 2008). I created a sphere, selected hemisphere, typed in .5, added normal modifier, clicked flip normals, but I still cant see through the dome! Am I forgetting something? The tutorials only tell me those steps. It is annoying to zoom extents and to not see my scene. Link to comment Share on other sites More sharing options...
mahorela Posted August 9, 2007 Share Posted August 9, 2007 I may be reading this the wrong way but if you create a skydome....flip the normals and then zoom extents won't your view be on the outside of the dome and therefore you won't be able to see it (flipped normals)? alternatively.....if viz is like max, right click the dome and go to properties and click on the option that says "see through"......this may help you to see your scene through the dome Link to comment Share on other sites More sharing options...
louis.cho Posted August 9, 2007 Share Posted August 9, 2007 can you not just hide the geometry and make it visible to render? Link to comment Share on other sites More sharing options...
neko Posted August 9, 2007 Share Posted August 9, 2007 is the skydome properties set to cast shadows ? it shouldn't Link to comment Share on other sites More sharing options...
Tommy L Posted August 9, 2007 Share Posted August 9, 2007 Your viewport is set to 2-sided. Change it in the customize settings. Link to comment Share on other sites More sharing options...
