TheAllusionisst Posted August 8, 2007 Share Posted August 8, 2007 Quick question to see if anyone has run into this. I finally got my VRay dongle and plugged it into my server and wanted to uninstall and install Vray for dongle lisencing. Unfortunately a dialogue box comes up saying that 3dmax is running (have it installed for the renderfarm), which there is a max process always running and even if though through the task manager I stop the process, it just starts up immediately so I can't uninstall or install vray. Anyone run tion this problem and if so do you have a solution? Just trying to set up everything for distributed rendering, usually something like conflicts in IP's or similar would cause problems for me, this time I can't even re-install the software! LOL It has been one of those months Thanks in advance. Link to comment Share on other sites More sharing options...
rivoli Posted August 8, 2007 Share Posted August 8, 2007 if you had registered the spawner as a service that's what it would do, you can remove it via programs>chaos>vray>dr>administration>remove. this should fix it. Link to comment Share on other sites More sharing options...
TheAllusionisst Posted August 9, 2007 Author Share Posted August 9, 2007 That did it, thank you, I thought I had removed the spawner from all the autostart locations, so I was baffled. Thank you for your time and solution! Link to comment Share on other sites More sharing options...
pakos76 Posted November 14, 2008 Share Posted November 14, 2008 I am trying to uninstall vray but it says 3ds max is running even though is not!! Could anybody help me on this matter pls thanks in advance Regards Link to comment Share on other sites More sharing options...
kippu Posted November 15, 2008 Share Posted November 15, 2008 pakos it is the vray spawner...same solution as given above by rivoli Link to comment Share on other sites More sharing options...
pakos76 Posted November 15, 2008 Share Posted November 15, 2008 pakos it is the vray spawner...same solution as given above by rivoli Still not able to do it. I have deleted all the vray files manually but still have some when i go into panel control remove/add programs and when i click remove i get a window saying that 3ds max is running.... Plus if I try to reinstall Vray i get the same mesage.... sorry guys but i am not really familiar with this stuff and it is driving me crazy!! i really appreciate some help thanks in advance regards Link to comment Share on other sites More sharing options...
kippu Posted November 15, 2008 Share Posted November 15, 2008 press alt+ cltrl+del to get the task manager ...see a process called vrayspawner.exe and "kill it" and also stop a 3dsmax.exe which will also be running....that should do i suppose Link to comment Share on other sites More sharing options...
WAcky Posted October 18, 2009 Share Posted October 18, 2009 hilarious. Link to comment Share on other sites More sharing options...
