adding a background behind a window
salf
Ok, adding a background in PS is easy, I just either save my file in MAx as .png or Targa, so I wont have the background.
But heres the thing, im doing a interior scene, wher ethe cam looks to the outside, through a huge glass window, actually a curtain wall, so I cant use the same trick because I want to keep the reflections on the window, that meanst I render with the glass, so I cannot separate the max background in some alpha channel.
ANy ideas on how to tackle this sorta thing?
Im guessing Im stuck with adding the background I want in 3d MAX, but the colors are way off, so I was wondering if there were some tricks in photoshop for this.
  • 3 weeks later...
Guest nazcaLine
if you are using vray, then when creating a glass there is an option in the refraction section called "affect alpha" (or something like that). if you check it, you'll be able to keep the reflections and alpha. good luck
Eduardo
